You can put each sphere in a different file and and then in UltiMaker Cura, go to individual item settings and change the infill percentage for each sphere. Then you arrange the spheres the way you want. Finally, Select all the objects and right click on them. This should show a menu (You should click "Group Models", also, make sure to unselect "Drop Down Model" for a free range of motion) and then the shapes will be combined to make one object. I tested it myself, and it works.
Edited by KTec- 1
Slashee_the_Cow 271
I'm having trouble wrapping my head around this (although I am somewhat lacking in spatial reasoning ability, an illustration might help) - you want nested spheres, but with infill... doesn't that mean you'd just end up with a solid sphere the size of the biggest one?
