Thank you for the response. I´ve tried changing the settings as you suggested and I still get this issue in the beginning of every layer. I'll post another picture that might make it easier to see the issue. Can you help me? @Slashee_the_Cow
If you could provide the Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project) that might help, since I can look at the settings and where the Z seams are and such to see if anything strikes me as odd.
Although looking at your pictures, it seems like your project has a cross section something like this?
\_| |_/
You could always cheat. Since it seems to be the inner section giving you problems just do it separately in spiralize mode (no Z seams at all!) and glue it to the other piece 😉
Also I just remembered that @jaysenodell (I'm pretty sure, anyway) has been working with bigger nozzles lately (even if not quite that big) and notice that mention and possibly have advice.
Yep.. that was me. 1.0mm noz for big tubes that eat entire 1kg spools at a go. I'm dumb.
I found the problems to be
I get a textured surface (ridged) but no holes in the layers.
If you see underextrusion middle of a layer you may need to increase noz temp to help the booger string flow. I wound up at 200.
The two biggest factors were print speed (slower is better) and the prime amounts (there is more than retraction prime, that's the only one I needed to change).
Let me know if I can be of any help.
Well it's definitely prettier than a lot of models I've tried to troubleshoot 🙂. Some observations:
Okay, done with the observations. Now the suggestions (and I might be using some of the more advanced settings here so if you can't see them, just search for them):
55 minutes ago, jaysenodell said:Print speed - 50mm/s (my normal is 80mm/s which will make slashee call me names)
%!&*ing hoons in their Commodores doing 80 in a 60 zone. Where's a cop when you need one?
Slashee_the_Cow 267
It's hard to see in the photos (which probably means it's the sort of thing you're going to notice because you know it's there but other people won't).
If you want to increase the pressure after a retraction, increase Travel > Retraction Extra Prime Amount. Probably doesn't need to be too high, but I've never tried it so I can't offer specific advice on numbers. That makes it push a bit more filament into the nozzle than it retracted to make sure the pressure is high enough when you resume printing. Remember though, small scale testing is your friend: if this is something which is apparent even in the first few layers, then when you test after changing things only print the first few layers, not the whole thing.
Printing with a 1mm nozzle is always a bit hard but it's good to see you've (probably, I don't know your normal settings) accounted for that by lowering the speed and increasing the temperature.
I would recommend turning down the acceleration quite a bit (down to maybe 200mm/s²) and turning on Speed > Enable Jerk Control and lowering it to 4mm/s². Since you're printing at such a low speed this will help make the speed consistent because it's not turning a corner and zooming off as fast as it can before it has to slow down for the next corner (admittedly not too far in this case, but still).
You may want to try enabling Walls > Outer Wall Wipe Distance with a setting of about 0.4mm. This makes it so that when it finishes a wall it keeps moving the nozzle a little past the seam without extruding, the idea is if there's anything left in the nozzle it uses that to fill a gap in the Z seam if there is one.
