GregValiant 1,258
There are settings that can make the area small because Cura can decide it needs to reserve the space for something.
"Avoid Printed Parts when Traveling" is one. If you have "Prime Tower" enabled or are using a Skirt/Brim/Raft or if you have "Generate Support" enabled then the area can be smaller. For an UltiMaker it appears that just changing the material can effect the Max Model Size.
Generally, if there is a gray border around the bed it is caused by either a setting, or (for some printers) a disallowed area. With the settings just right you can slice a model that is 0.2mm less than the build plate X Y.
Edited by GregValiant
Slashee_the_Cow 271
The profiles for UltiMaker printers in Cura should be perfect (since they're added by UltiMaker themselves).
If you think the profile might be wrong for your printer, make sure you're running the latest version of Cura (either 5.6 or 5.7 beta) and add a copy through the add printer wizard.
