1 hour ago, muscato57 said:My wall problem appeared after the 5.7 update installation. These are my prints the red before the update, blue after. I’ve added density and walls but still get the blue outcome.
Anything will help.Thank you.
If something works fine in an earlier version but doesn't print correctly when sliced in 5.7, then you should submit a bug report. Make sure to include a Cura project file of the same model saved from each version (you can have as many versions of Cura as you want installed side by side, so you don't need to downgrade or anything) as well as the gcode from each version, and preferably photos of it printed from each gcode (it doesn't need to be a big model, just anything that will demonstrate the problem).
GregValiant 1,258
There isn't anything wrong with the gcode. Your printer is under-extruding by a lot. I happen to also have an Ender 3 Pro and it's a problem that showed up a couple of times.
Starting at the beginning:
If it isn't a broken pressure arm then it time for maintenance on the hot end. Warm it up to get the nozzle out. Take it apart and clean it out. Trim the bowden tube back by about 6mm (with a nice square cut) and put it back together. Warm it up again to get the nozzle back in. It should be snug.
My printer came with a 1.1.4 "loud" board. I had the machine a month or so and it was driving me nuts so I ordered the 1.1.5 "silent" board. The first one had the E stepper driver fail after 1 week.
Another time the under-extrusion started the problem was the not end. After fooling with it a bunch of times I went with an "all-metal" hot end.
Edited by GregValiantLink to post
muscato57 0
Anything will help.
Thank you.
