Hello! Sorry, forgot the 3mf. Here it is: FSR_2024-04-08 (4) Fot seam test.3mf
The reason for the spine is to be able to get a straight seam on the feet. Without the spine the seam is not straight. Maybe there is an easier way but this spine is not visible when printing and allows the seam to be straight.
Slashee_the_Cow 620
Hiya!
It's always easiest if you can post a Cura project file (.3mf, in Cura set it up ready to print then go to File > Save Project) that way it sets up an instance of your printer and copies all the settings in as well as the model.
Is it just one column you're having trouble with or all of them? Because looking at the STL I see that they all have a thick spine for some reason:
But for one of them that line also goes around to the side and then down the edge:
Or is that intentional? I have no idea what you're trying to make 😕
Also (and I'm not saying this is your problem but it's good practice) when I imported your model into Cura I got a warning that it wasn't watertight. Thankfully there's an awesome plugin called "Mesh Tools"
With that installed, I had to do was right click your model and select Mesh Tools > Fix Simple Holes and it fixed that problem.
I'm happy to do a more detailed look into it but that's probably not a good idea at 1:30AM so I'll get back to you later on that one 🙂. If you could post the Cura project file it'll be a lot easier to see how you've got it set up.
