43 minutes ago, Slashee_the_Cow said:Ironing has little to do with spiralise mode, as there's no top skin to iron. If you could provide a Cura project file (.3mf, in Cura get it ready to print and go to File > Save Project) then we can see what's up.
I don't know what version of Cura you came from (there is no 4.17, the last release in the 4 major version was 4.13.1) but it's possible the default behaviour has just changed.
If it's the last part to be printed then you could just remove the commands from the gcode file manually, although obviously that isn't an ideal solution if you need to print more than a single model spiralised.
Thank you for your reply.
We just checked and it's Cura 4.13, not Cura 4.17.
We mainly use ceramic 3D printers to print ceramic vases. Due to the existence of the last circle, the already printed model will be scratched. Although manual deletion is relatively simple, it needs to be changed every time, which is more troublesome. Please see the Attachment.
Thanks again for your help.
E-cylinder-50-100mm.3mf E-cylinder-50-100mm.gcode
Edited by Jonysix
Slashee_the_Cow 620
