It's possible your filament is a bit damp - PETG is hydroscopic (absorbs water from the atmosphere) if it's too damp it gets a bit slippery so it's hard to extrude, and gooey when heated up so it doesn't come out of the nozzle cleanly.
Also, I'm sorry if the following sounds a bit critical, but I'm just trying to educate 👩🏫:
4 hours ago, newdeal99 said:I was printing infill first to help with overhangs
This often doesn't work as well in practice as it does in theory: in theory, it gives the walls something to hold on to when they get printed. In practice, it can push the walls further out and a bit too far over the edge.
5 hours ago, newdeal99 said:Elegy rapid PETG
I've yet to meet a "high speed" filament that prints just as well at its recommended speed as a regular version does at its recommended speed, so make sure you're not going too fast.
GregValiant 1,490
Welcome in here. It's always good to start out by mentioning the printer and any customizing that was done to it.
Load the model (if you can share it) set Cura up and use the "File | Save Project" command. Post the resultant 3mf file here. It will contain the model, your printer, and all your settings.
PETG can be difficult. It gets gooey and stringy, and wants to stick to the outside of the nozzle. When enough material is stuck on the nozzle it will drop off on the print. I print about 75% PETG as most of my stuff is functional or will be outside.
Temperature is important. Long retractions are necessary. I print PETG a lot slower than I do PLA. At 35mm/sec for the outside walls and with no fan - they look nice and glossy.
Sometimes things don't scale up well. Other times a small scale will help hide issues and scaling up just scales up the size of defects that existed in the test model.
