That shouldn't be a "cura" thing as G29 is marlin controlled. I do see the G28 preceding the G29. Is the G28 executing? Meaning are you seeing the machine home all the axis properly?
It sounds like marlin is losing 0 on X. I have this problem on my ender as well. I have G28 as the first line in my start up code just to get 0,0,0 set before ANY other code is executed. After that I think G28 gets called a few more times, which is a pain, but it does seem to stop the "where am I" confusion I was seeing with creality's not so good version of marling on the e3s1p.
Slashee_the_Cow 269
Have you tried running an ABL from the printer's control panel to see if it will reset it internally or something? Enders can be finnicky beasts
