Ah interesting. I'll have to test that out.
Maybe in a future update they can better name it "Support Interface Extruder" 😀
On 4/12/2024 at 11:15 AM, GregValiant said:You must enable the Support Interfaces or the settings will be hidden.
Thanks, Greg!
I would like to do this with my UM 3, but when I enable the Support Interface and change "Support Extruder" from Extruder 2 to Extruder 1, all but two of the support options below it disappear. I suspect this is caused by the explanation/issue I see when I hover over the entries:
"Affected by"
"Support Extruder"
Going back to the default Extruder 2, if I change the entries in a different order, I get
"Affected by"
"Is support material"
I can never get the the full list of support fields populated with "Extruder 1", as in your example.
Extruder1 has an AA .4 core and Ultimaker Nylon.
Extruder2 has a BB .4 core and Ultimaker PVA
Must I denote Ultimaker Nylon as a support material and/or AA .4 core as a support extruder somewhere?
Make sure the second extruder is enabled
29 minutes ago, LePaul said:Make sure the second extruder is enabled
It seems to be enabled. This is a small model (the missing metal bushing in the bottom of one of my filament feeders) so it doesn't really benefit much from using extruder 1 for support but I'm using it to try out the concept.
But this is what I get when I change the support extruder to #1 (before and after):
See how only three of the original six Extruder entries remain?
This used UM 3 is my first experience with dual extrusion. (I wanted a 2.85mm all open source machine.) I assembled a UMO kit in 2012, now highly modified and still running well!
Thanks for your prompt reply, LePaul!
Cal
32 minutes ago, GregValiant said:When you set the support extruder to #1 it seems to turn off "Enable Support Interface" and that's why your other three options disappear. You will have to go back down and re-enable the interfaces and you should be OK.
Yes--that was it, Greg. It would've taken me forever to find that without your help. Thank you very much!
In playing around with these support settings, it seems that the dependencies logic of Cura sometimes changes the outcome of enabling or changing selections based on the order the changes were performed The only way to achieve a desired outcome sometimes seems to require changing all support features back to their default settings and then starting over.
Edited by calinb
Slashee_the_Cow 620
Set Support > Support Infill Extruder to the first extruder while leaving Support Extruder as the second extruder.I'm close, but wrong. See @GregValiant's answer below.
Edited by Slashee_the_CowI'm wrong
