Hi Slashee,
Thank you!
You are correct, according to the g-codes, I printed the ABS at 240/90 °C. I printed through a 0.2 mm nozzle using a Creality Ender-3 onto a glass bed with a lot of Magigoo adhesive, successfully.
But my luck has since ended on the Ender-5 S1 (hopefully, temporarily).
My first prints on the Ender-5, over the last 48 hours, were also on a glass bed with Magigoo. I just got the machine April 12. And I think you are correct, that I was using the wrong temperature settings. But I have since changed those and am running into other problems.
I believe I failed to adhere the glass bed evenly to the Ender-5 bed surface. Perhaps the glass bed was subject to inconsistent heating and some movement, because leveling the bed was extremely troublesome and the printing results were equally bad.
Photos of the Ender-3 results are those of the four ABS 3D prints (at the top), and the subsequent two images below. The image on the bottom is from the Ender-5.
I need to work with ABS because I am subjecting the finished prints to temperatures of 60 - 65 °C (embedding the finished prints into hot wax).
I use an ATM receipt for leveling and use an infrared digital thermometer to check the bed temperature.
Frustrated, I removed the glass bed today, I may try to adhere it again, tonight or tomorrow, using something more substantial than adhesive spray — something that will both adhere and conduct the heat evenly.
I expect to receive a PEI sheet on Friday and will try it then.
If I try additional prints on the glass bed this week, I will upload photos and the 3MFs. These little squares are small, and thin (and separated from one another by only a couple millimeters. I would like them to pop off after cooling, which is why I use the glass bed, atm.
I will try the PEI bed, but these thin ABS prints might just bend with the PEI, and not pop off like a solid object would.
Thank you again, your comments are very helpful. I appreciate it!!
Slashee_the_Cow 268
I've never seen any ABS print that cool (unless that's a typo and you meant 260°). I always ran mine at 255°. Until I stopped bothering using it.
It would help if you could provide a Cura project file (.3mf, get it ready to print then go to File > Save Project) so we can see all your print settings.
ABS is very hard to work with. If you're lucky, it has the adhesion of a wet paper towel. If you're not, it has the adhesion of a dry paper towel. It's also so temperature sensitive it warps if you even look at it funny (I put my printer in a tent, second to fourth best thing after a printer with an enclosure).
About your print settings: drop the jerk. If I'm going for quality I usually drop it to 4mm/s. This is especially important since jerk is the amount of speed it is allowed to instantly change at a corner.
It's highly likely it has very little to do with print settings and more about ABS' lack of adhesion and how easily it will warp.
A smaller nozzle won't really print sharper corners, just thinner lines, although that will help with the appearance of sharpness. Remember that a nozzle is round and filament will ooze a little bit so you will never get perfectly straight, flat edged lines.
If you're printing straight onto the bed you need to make sure it's as level as humanly possibly even before you run ABL (if you have ABL, far too many Enders to know them all). Assuming you can level it manually (you can't on printers like the E3V3SE). People will suggest various kinds of paper to use as a guide for how close the nozzle should be, back when I had a printer you could level manually I used a feeler gauge at .08mm.
However my ultimate suggestion? Don't bother with ABS unless you have a really good reason to. People insist it's stronger than PLA, it isn't, just a little less brittle (if I want something which is less brittle so it can have a bit of bend, I use PETG). Also the fumes from printing it are poisonous. Plus the aforementioned adhesion and warping problems (I've done prints where it won't even adhere to itself). It's a great material if you're using it in an industrial injection moulding machine (Lego uses a secret version of ABS) but not that great to print with at home.
