Posted
· S5 didn't recognize it ran out of filament
Go through the menus. Pretty quickly you can find an option to enable/disable the filament sensor. I have an S5 but don't use the filament sensor and I have never run out of filament. It's not that hard to make sure there is filament on the printer but this a nice feature sometimes.
Posted
Thanks gr5!
I went into the menu, and as soon as I enabled the sensor, the ongoing print paused. So it seems someone has disabled it due to it not functioning properly. I will look into this next week.
fideco
gr5 2,176
