davendw 0 Posted March 25, 2014 in CuraEngine Config file. Does anyone have an example of the config file used in the command line CuraEngine? Is just filled with the settings seen in settings.cpp? Also, if I wanted to create a solid fill object should I be trying to set all the layers to skin? Is there a specific setting for that? Thanks, Dave Share this post Link to post Share on other sites
gr5 897 Posted March 25, 2014 in CuraEngine Config file. I don't know about command line. But there are 2 ways to make solid layers - one is set the skin to say 200mm. That works fine and gives you concentric fill. Or you can set the infill to 100% which gives you diagonal fill which alternates each layer. 100% infill is not much (any?) stronger than 50% infill but is heavier, uses more PLA and takes longer to print. Share this post Link to post Share on other sites
amirps 0 Posted June 18, 2014 in CuraEngine Config file. Dear davendw, I'm trying to use a saved profile as config.ini , with curaEngine what I write in console is CuraEngine.exe -c config.ini -o res.gcode test.stl but it returns an error "Failed to read config 'config.ini'" did find a way to sole this error ?! Share this post Link to post Share on other sites
