Hi there,
I'll think both, Cura (5.70 & 5.71) have this new setting for use of "Skirt"; "Skirt Height" default 3 lines.
Just change this "Skirt Height" from 3 to 1 and it will be as before..
Thanks
Torgeir.
Hi there,
Thanks
Torgeir.
10 hours ago, Torgeir said:I'll think both, Cura (5.70 & 5.71) have this new setting for use of "Skirt"; "Skirt Height" default 3 lines.
It's not a new setting. The skirt height setting was added in 5.4.0.
But yeah, just change skirt height to 1 and it'll draw a skirt (which is more just to make sure your filament is adhering, and possibly get rid of any crud in the system, doesn't help the model at all) only on the build plate. I have no idea why the default is 3.
Slashee_the_Cow 291
If you could post a Cura project file (.3mf, in Cura get it set up then go to File > Save Project) of a print which demonstrates this problem so we can see all the settings you're using that would really help. Something like this can be hard to troubleshoot just based on description alone.
