Ideally if you could post a Cura project file (.3mf, set it up, then go to File > Save Project) then we can look at the original model and your settings and see if there's anything that stands out, and if not, just play around with the settings until it works and tell you which ones to change 😄
Hi Guys.
You can see here a full view of the CAD modelUMS5_3D scaled for 3D print V3 - sterm .3mf and the 3mf file
The material which i want to print this is CPE and EVA as a support material and i am printing from a ultimaker cura S5
Every tip / help will be welcome.
Thank you
Dustin 193
your going to want to post pictures of the before sliced model.
