I don't know if this is right, but I've found that looking at it like this gets my head around "Infill".
There is a block of infill that encompasses the entire build volume. Cura uses those portions that intersect a volume of the model where there should be infill.
Consequently, the "mid-point" of the infill pattern is at the mid-point of the build plate.
If you move that block to X0 Y25 (1/2 the model depth) I think you'll get what you want. Cura's "block of infill" will stay where it is, but you will force a different "intersection" with the model.
FWIW, you don't have to set the line directions to [90, 90]. Just [90] will work fine, each layer it goes to the next one in the series and then repeats, so you only need one and it'll repeat that.
GregValiant 1,271
GV Solid cube.3mf
Slashee_the_Cow 291
Souvik20 0
@GregValiant Thank you so much. It worked :).
