The bed is indeed as level as I can get it.
I have been playing with the Z offset as well, but to get it right, it seems that I have to adjust it during the print, otherwise the hot end will be either too close to the bed, or so far above it that the first layer won't stick. So the first layer has to be good, then I have to adjust the Z offset on the screen to correct the distance. Which makes a very difficult print each time.
Slashee_the_Cow 619
I know this one is obvious but I'm going to say it: checked to make sure your bed is level and your Z offset is correct?
