GregValiant 1,319
I use the ends of filament rolls for practice for things like pausing and testing post-processors. I decided to print the 75% model to keep junk in.
At this point it has about 70 layers to go. This is "Spiralized" so it is a single wall at 0.60 Line Width.
Prints that require very specific support can be difficult. A print like this is just a print and once you get the bed adhesion figured out it will print well.
- 1
champsteve778 1
If the planter is too advanced, here is a smaller one
I tried to print with same settings I used for the planter and the same thing happened as did to my planter that I showed you in the video. As in a messy start.
Thanks in advance,
Steve
CE3E3V2_roman-small-cup.3mf
Edited by champsteve778Link to post
