5 hours ago, jaysenodell said:This may be specific to my brand of stupid, but printing slower "fixed" it for me. That said, I would expect that points to either a flow rate increase, a temp increase or other, more diffictult to make exact, set of changed to make "print faster" better-er. I just plan more time for printing as everything seems to work really well with slower printing.
I played around with the speeds quite a bit and nothing changed. I feel like it has something to do with my top/bottom settings. The lines match up with each horizontal plane of the chep letterings. Adjusting the jerk helped it only the slightest bit, so I lowered it and then played around with the other settings, but no luck.
Edited by MrLonnie
Slashee_the_Cow 351
The project file you posted doesn't contain the model - you might want to fix that.
jaysenodell 17
