Problem Printing Embossify
kas
Posted · Problem Printing Embossify
It appears that Cura cannot print the STL output from Embossify (http://www.embossify.com/). The file loads and appears on the platform, and then Cura seems to freeze. Embossify is a service for converting 2D jpegs to 3D STLs. I'd appreciate any help or suggestion.
    Have you tried it with Cura directly? You can just load the jgp. If you're not satisfied with the result, you may export an STL and tweak it with another software.
    btw: welcome to the forum... ;)
    Heuh?
    WTF... Loading a jpeg in cura? woohw.
    Tought they where busy with serious things at Ultimaker ;)
    But chips.. It works haha.
    Something to play with this afternoon LOL.
    Mind. Blown. Amazing feature!
    IMG 0924
    My Logo 0.1mm layer, PLA printed with an UP Mini with RAMPS electronics;)
    Ok... not sure how that helps kas though Fredee? Was it just to put your link to your site out there?
    Thanks a bunch; your suggestion worked like a charm :)
    sorry, it is to show how good cura can convert jpg's into 3d printing files, nothing more;)
        • 4 replies
