4 minutes ago, Dustin said:You might need to do a clean install of there slicer for it to work and record everything before launching UltiMaker Cura.
Its been known now that some of these 3rd parties dont bother to change the default config folders use by their version of Cura and it gets mashed in with the Default UltiMaker Cura configs and corrupts one or both of the installs.
I'm not sure how to do clean un-install from that version....uninstall and delete the %AppData% folders?
When I did have it running, I saved the Project file and tried to open that in 5.7.2 I could only get the part to load, not the machine settings. Usually I can get the printer settings out that way.
Edited by LePaul
Typo
Dustin 146
