problems with the bed
Posted · problems with the bed
Hello,
 I have a defect on my Ender 3 S1 printer.
The problem occurs when printing the first layer.
It seems that the surface of the bed is not homogeneous. In fact, the nozzle is at the right height in certain areas of the bed (in the middle, for example, the first layer adheres well), but is too high in other areas (generally on the right-hand side of the bed, the first layer is printed too high and doesn't adhere
Thanks in advance for your help
    Posted (edited) · problems with the bed
    Check your Z Axis offset and the double check the corners of your bed level. Almost always is the culprit for me when I encounter this issue. If you haven't already do an auto-bed level and be sure to save it after you tweak the corners.
    Edited by AXH_127
    "Creality" and "completely level build plates" are only things that belong in the same sentence if there's a "don't" or something like that in there (why do you think the BL-touch became so popular Creality ripped it off?).
    There's one thing people often don't consider when levelling a bed by the corners: it needs to be correct height at the home position as well as the corners. ABL will only get you so far and it usually bases those values on the home position.
    • Laugh 1
