What is the purpose of these?
terrypin
Go to solution Solved by Torgeir,
  • Solution
Posted (edited) · What is the purpose of these?
Hi @terrypin,
This are just the status bar for; "Infill" set to 20%, "Support" (Not used) off and "Build Plate Adhesion" (None selected) off.
This whole area  open or close the "Print Setting Menu".
That's all.
Thanks
Torgeir
Edited by Torgeir
More text.
  • Heart 1
Posted · What is the purpose of these?
Further to what @Torgeir said, it's more relevant if you're only using the basic settings window because those are all the settings that are available:
But it's still handy to quickly check what your settings are even if you're using the advanced settings.
  • Heart 1
Thanks both, understood. BT Broadband down so far all day. Sending this from iPad via my wife’s TalkTalk router. Keen to get back to Cura on my PC.
Is there a ‘help hover’ setting I can use until I re-familiarise myself with the UI.
Edited by terrypin
        • 4 replies
