Further to what @Torgeir said, it's more relevant if you're only using the basic settings window because those are all the settings that are available:
But it's still handy to quickly check what your settings are even if you're using the advanced settings.
Torgeir 274
Hi @terrypin,
This are just the status bar for; "Infill" set to 20%, "Support" (Not used) off and "Build Plate Adhesion" (None selected) off.
This whole area open or close the "Print Setting Menu".
That's all.
Thanks
Torgeir
Edited by TorgeirMore text.
Slashee_the_Cow 454
terrypin 3
Thanks both, understood. BT Broadband down so far all day. Sending this from iPad via my wife’s TalkTalk router. Keen to get back to Cura on my PC.
Is there a ‘help hover’ setting I can use until I re-familiarise myself with the UI.
