Dim3nsioneer 557
You may disable combing in Cura (expert settings). Then you'll get retraction on all layers.
If you want retraction on the first layer only you may use the RetractionWhileCombing plugin (to be found in the UM Wiki, wiki.ultimaker.com).
alnavasa 5
