No wait, according to the help tooltip for spiralize it does a single wall so it ignores the shell setting. And the print really does look like it is a single wall - it is very thin.
Ok, I understand now what you say. Then I could simply either reduce flow to 50% or re-slice and chose a 4mm shell.
thx.
But it does 2X extrusion. In cura look at meters of filament used. Then change shell to .4 and you will see it will reduce by quite a bit (the part for the wall - the base will use the same amount).
Yes, but not until it gets to the wall.
I recommend at least .5mm shell by the way. If you want this to be watertight.
gr5 2,243
Actually it is trying to do 8mm^3. I'm impressed it did so well.
The problem is with spiralize: it does it in a single pass so it is trying to do 200% flow to get that shell of 0.8. It's tough to squeeze .8mm wall out of a .4mm nozzle so it just can't quite do it. I think if you do .5 or .6mm shell you will be good.
