Need to find replacement button for Ulticontroller of UM Original
rarena8690
Posted · Need to find replacement button for Ulticontroller of UM Original
Hi Everybody,
I recently purchased a UM original. I need to replace the knob in the Ulticontroller. My hopes were that I could just de-solder the current potentiometer/pushbutton and replace it with a new one. Does anybody know what type of button this is and where I can purchase it?
I really need this to use the conroller!
Thank you very much a please help!
rarena8690
    According to the BOM the encoder is:
    EC11E15244B2 729-5609 ALPS EC11E15244B2 20mm Vertical encoder 15 Pulses 30 DET
    The second number is the RS partnumber.
    If you just need the actual knob it is available as a STEP file so that you can print it:
    https://github.com/Ultimaker/UltimakerOriginal/tree/master/1129_Knob
