You broke Q4. The darlington transistor. It is easy to replace if you have beginner soldering skills. This large 3-pin part is located very close to the fan plug. It is not an expensive part.
Thnx you very much. I will try it and let you know!
I think that’s true that yow blew the Darlington transistor and you can easily find it as it is black 3 pin devices and moreover you can also find it on the PCB as it is designated as Q4 on the PCB.
gr5 2,333
