Haven't looked at the STL to see whether it looks printable without support. But you definitely want the shell thickness to be more than 0.4mm - that's just a single pass of the head. For something like this that needs some strength, you probably want at least two passed - 0.8mm. For the top and bottom thickness, you need at least 5 or 6 layers to ensure that any bridged parts or infill gets properly covered. So with a 0.2mm layer height, you need a top/bottom thickness of 1mm or more.
illuminarti 18
Is the clicking your unhooked fan shroud catching on the print?
