Cura 14.03 Slicing direction going from top to down
Minkeproducts
Posted · Cura 14.03 Slicing direction going from top to down
Dear all,
1.In cura 14.03 Windows 8.01 the slicing process is shown from top to down. In that way it is difficult for me to see a simulation of how the object is going to be printed. Is there a reason to show it this way?
2.Can I find somewhere an explanation of the colours used, in the slicingprocess?
Images at;
http://umforum.ultimaker.com/index.php?/gallery/album/806-cura-1403-slicing-direction/
Thanks in advance :-P
    Once the slicing is done you can go through the layer with the scroll thing at the right side of cura.
    For the colors i'm not 100% sure but here is what i understand:
    Light Blue is support material
    Red is the outer shell
    Green is the inner shell
    Yellow is infill
    Dark blue is the head moves
    Correct me if i'm wrong?
    Non printing moves. Yes. Also if there is a vertical blue line that is a way to represent "retraction". Retraction is used when printing between 2 or more "islands" in a given slice.
        • 4 replies
