No-no the motor is fine, I printed already 1 time a 20 mm cube. No problems there.
and in ReplicatorG version: 0026 I had some control over the extruder fast and slow , but not over de program...
No I think',..... It must be software relayted... All the hardware worked at leased ones...
how do I know if python works ? what does it do...?
and I am use-ing slic3r 0.7.1 or is skeinforge 40 better?
Daid 305
The extruder motor never turns? I don't think that's software related, but more likely a problem in the hardware. A bad connection to the extruder motor, or a bad motor driver, or bad current settings on the motor driver.
You could try swapping out the extruder motor driver with the X or Y driver, to see if it's the driver problem or something else.
