So I suspect 72 is correct. The UM1 uses the arduino mega2560. I don't know which arduino chip the UM2 uses.
UM2 uses the same chip. The UM2 hardware started by just putting all the UM1 hardware on a single board. And then replacing the bits that where not needed or could function better (like the temperature measurements)
gr5 1,843
Did you use this for your source?
https://github.com/Ultimaker/Ultimaker2Marlin
If so then in Configuration.h I found:
