Bumping solved, thanks. (Never had the "singles" active before.)
But it still refuses to slice... the button is simply greyed out. If I switch to 0.2mm the button is no longer greyed out but it still doesn't slice... just says 0 hours. The program doesn't lock up or anything...
gr5 1,968
You can disable this by going to "tools" and choosing "print all at once".
Don't know why you can't slice. Try .4mm layers just for kicks to see if that helps as it slices much faster when layers are thicker. There is a log file somewhere that might show what the problem is.
