The wire on the bottom probably isn't supposed to be connected to anything. Check that the 'fan pwm' connector is attached (it's near the side of the printer).
Secondly, the fan on the back of the print head should run all the time. Does it?
Finally, pull back the sheathing around the cables above the printhead, and check the connections there. There should be three red-black pairs; one is slightly longer and goes to the fan on the back. Two others go to the yellow/green wires - those are the side fans. Check that they are all plugged in, and the wires are properly attached.
gr5 2,192
I couldn't open the pictures. Please post picture again:
How to post pictures:
http://umforum.ultimaker.com/index.php?/topic/4525-how-to-upload-an-image-to-the-forum/
