Cura slicer questio.
tonycstech
Posted · Cura slicer questio.
How would you solve this one?
Found out that CraftWare does not solve this by continious path, it makes each run seaparate when it can to avoid complicated pattern generation.
Look at the image below and see.
21
I think its easier to just generate each loop individually instead of having a continious path. All you gotta tell it to is to where to switch from one to another.
    • Replies 50
    • Created
    • Last Reply
    Top Posters In This Topic
        • 27 replies
