Cura RC2 has a bug in the support, it doesn't lay down enough material in the first support layer. It's actually laying down material for a layer thickness of a normal layer, and not the thicker first layer.
In the development version this is fixed, and it will put down 100% support material for the first layer, so the support really sticks well (even if you give in 50% support material, the first layer still has 100%). Sadly, I found and fixed this problem 3 days after releasing RC2.
IRobertI 520
When I see signs of the first layer not adhering properly I usually just give the z-axis screw a little twist, one or two "snaps" is usually enough to get the head to really smush the plastic down into the tape. I gave cura a quick try last week and I think by default it's set to make the first layer thicker (as in higher) than the other layers. Personally I think that's wrong and I set it to be the same height as the rest of the print.
Nice job with cura btw daid it's come quite a long way since I first tried it, I'm still sticking with Netfabb but alternatives are always good
Aand now that I've finished typing I realise that you're really only having trouble with the support and I now feel like an idiot. My head are a million places at once lately... Carry on! :lol:
