Ultimaker 2: Z platform problem
linusn
Posted · Ultimaker 2: Z platform problem
Hello,
we're having problem with the z platform on our Ultimaker 2.
During prints the z platform drops or losses a few steps.
Here is a video to better describe what is happening. 10 seconds into the video you can see what happens.
The drop doesn't happen on the exact same spot each time but usually around 10-15mm into the print.
We've tried to print different models with different settings but the problem persists.
We've also put some of the green grease onto the threaded z-rod, and tried to see if there was a problem with the threads but we could not see anything that appeared to be at fault.
Any ideas or suggestions?
Thanks,
/linus
    Its a bit hard to see whats happening before the drop... is it just that it's moving/falling too far when that big clunk happens, or has it not been moving properly in the previous layers, and now it's catching up? It looks like it's happening on the intended layer change, as it immediately goes to printing perimeters afterwards.
    Hi illuminarti, thank you for your response.
    Sorry about the bad video.
    Too me at least it looks like it´s printing fine until the drop happens.
    Like you said the drop happens on the intended layer change.
    I thought that perhaps it was a problem with the threads but I presume it would happen at the same location each time then, which it doesn't. Even if it is in the same general area.
    I really don't know what's going on, hopefully someone has some insight.
    /linus
    • 11 months later...
    Hello /linus,
    I have a similar problem with my new Ultimaker 2 - in my case the plate drops a few mm, more or less randomly when I process the same file several times. Everything works fine with the print until the drop happens - afterwards the printhead prints into air and I get a kind of plastic wool.
    Did you find out what is causing the drop?
    Greetings
    wolfgang_theiss
        • 9 replies
