Sander speaks truth.
If the filament reaches 3.01mm it will probably get stuck in the clear bowden tube. Difficult to get out.
There's lots of techniques to get PLA to stick to glass. Thin layer of glue stick and bed temperatures above 40C is usually good enough. With large prints you also want brim.
It also helps to have the first layer pressed firmly into the glass (leveling is important) and you might want to print a bit hotter and slower for the first layer (240C). Cura normally prints slower for the first layer.
But for parts < 80mm glue and 60C is usually enough.
SandervG 1,518
Hi Rob,
Is the filament exactly 3.0mm or is it within the 3.0 range but it actually is approx. 2.85mm ?
3.0mm would be the max, because the ID of the bowden tube is 3.16mm and 3.0mm may create some friction.
For PLA you don't necessarily need glue, but if it is a rather large footprint you may want to use it.
For ABS you do want to put some glue on the bed.
Heat up the bed to 65ºC and for most (PLA) prints you should be fine
