Your example shows bridging. Cura is starting a "bridge" right at a un-rectract. This is not common so it seems like a bug/feature that hasn't been thought about much in the past.
Cura doesn't always properly detect bridging. When it does, the behavior is a little different. I'm not sure if Cura failed to detect bridging here or if it *did* detect it but allows a un-retract. Daid will have to comment.
An obvious fix would be to add some infill. Also if you do thinner layers it might help on this particular design. Also doing a thicker shell (.8mm is two shell passes. Better than .4mm - one pass).
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
gr5 1,841
