Thanks gr5,
you are right, no problems when starting fan at 100% at 2nd layer. Didn't know PWM was used for controlling the fan speed, it makes a lot of sense that this is the cause. And now I finally understand what that little circuit board is for...
I'll change the wiring - seems like a good idea to use another hole in the printhead for the fan wiring, and I'll make sure to twist those fan wires.
Still strange though, as it didn't have any problems with these intermediate fan speeds before, and I made no changes to it - the problem started "spontaneously".
Is it possible that the output of the probe has become weaker due to aging ?
Or is it just a heat-sensitive resistor ?
gr5 1,516
It's common for the PWM signal from the fan to interfere with the temperature probe.
One solution is to disable PWM by using the fan ONLY at 0% or 100%. This is probably the change you have seen recently - the more recent versions of Cura (last few months) turn on the fan more gradually. This is more in response to the UM2 design and not as critical for UM Original.
Another (better) solution is to separate the fan wiring from the temperature probe. You only have to worry about the 50mm or so between the heater block and the board on top of the print head. Usually a distance between the cabling of 20mm is enough. Twisting the fan wires will help.
Another solution (maybe) is to use a copy of Marlin that uses "slow fan PWM". You can do that by unchecking the 4th checkbox from the bottom here. This won't eliminate the problem but it will cause less frequent spikes in the voltage so that hopefully you get less frequent "bad temperature" readings.
http://marlinbuilder.robotfuzz.com/
