Pronterface UI shows up, conneting.... Closed.
No connection to the printer.
Any help considering installation of different versins of Cura on Ubuntu 14.04 64 bit would be welcome.
If I download the older .deb file out of http://software.ultimaker.com/?show=all I recieve following message:
"Er is al een nieuwere versie geïnstalleerd" meaning that there's already a newer version installed :(
How to git pull an older version of the Cura tree?
Maybe I'll try the PinkUnicorn if it's available for Linux ;-)
Greetz,
Xiao Shi Zi.
Removed the new version and installed the 13.11 back in place :(
So whenever I'll need line support I'll need to update slice save G-code remove version, install older version and print... Changing a parameter and restart the print will be fun.
Enjoy the weekend :wink:
Greetz,
Xiao Shi Zi
gr5 1,968
You might want to continue printing with older Cura. The nice thing about Cura is each version is a completely different application so you can install many versions.
However you can get a few more features in your print window if you go to "file" "preferences" and choose "pronterface" instead of "basic".
People are writing better plugins but it may take a while. There are some other interfaces here on the forum somewhere.
