Posted · print one at the time - adding issue
I noticed that sometimes the print one at the time feature seems to roll back to print all at once when placing the objects to print in cura even if the option remained set to print one at the time.
I can reproduce the issue by simply loading more objects in after placing a few already. I use drag and drop to add the objects and basically every time I add a new one the print head bounding box arount the object goes back to minimal size instead of staying full size.
I dont know if it will actually print one at the time with wrong placment or not but that could mean smashing into other prints.
Its easy to fix on the user side but its always better to not having to.
Thanks
    Yeah I've noticed this as well, but I haven't paid attention to any reproducible pattern.
    You can easily check if it will print all at once or not by going into the layer view though.
    Any objects higher then the gantry height (55mm by default) will cause Cura to go into "all at once mode"
    Also, it tries to figure out a printing order without collisions. It it cannot find that, it will do a "all at once". But should be quite rare...
    Make sense since some of the added parts were put of the print range and some needed to be rotated sideways to be printed properly.
    Still the option in the menu should properly reflect what the slicer will provide as output.
    The latest time it happened for me was when I was printing a copy of my feeder. All of those parts are comfortably below the 55mm limit. I'll see if I can reproduce the conditions some time. (if I remember..)
