Thanks Dim3nsioneer,
great idea, filling in everything before loading the object!!!
Perfect - I'll give it a try.
Doesnt tweak at z support layer number AND height in mm? If you mass produce you shoukd be able to have one setting the height 0 setting speed at 40% and one setting at height 1.0mm (10x 0.1mm) to set speed at 100%.
Wouldnt that work?
PS: dont forget to remove the setting for your next unrelated print since they stay saved in cura.
PSS: I share your pain in the slow slicing...
Dim3nsioneer 559
I assume you refer to the TweakAtZ plugin when you write 'z-plugin'.
I recommend you fill in everything you need BEFORE you load the first object. As long as no object is loaded, Cura doesn't slice.
When everything is filled in as you want it, load the object and Cura will slice it ONCE.
The TweakAtZ plugin needs some time as it is a Python script which needs to be interpreted and not a compiled software. The plugin has been extended during the last few months. If you want to try an older version with less features you find the old versions at the http://wiki.ultimaker.com/CuraPlugin:_TweaktAtZ. For the present version 3.2 I recommend not to use more than five instances of the TweakAtZ plugin.
