It works fine for me. I just tested it. Are you cancelling the print after it starts printing or before?
If all you want to do is stop nozzle temp from increasing after cancelling a print you can turn off power or you can go here:
maintenance->advanced->nozzle temp
tks gr5,
Story :The bug was my daughter found ,and question me,how can i fix it when Tune "cancel button " can stop print and the nozzle temp can not go up?
Try: I try to search menu "cancel button" code in firmware,and the function is run "G28",google the G28 code,it means Home.Ok, i understand it. I try other can stop print g code when the nozzle temp is heating,but failure :(
Help:how can i fix it for my daughter? she is very love the printer.
gr5 1,871
