Posted
· Bad prints - Layers messed up holes - UM2
This is standard underextrusion. I've seen it many many times.
There are many causes - for example as you get to the last 1/3 of the spool of filament the radius gets tighter and the PLA gets stuck more in the bowden and especially in the white teflon isolater just above the nozzle.
One quick fix is to simple print slower and/or hotter (half speed, print at 240C, don't go over 240C).
Another quick fix is to put the filament spool on the floor as the angle it enters the feeder is a problem (lots of friction).
Other causes are clogged nozzle, deformed isolator, ground up filament at feeder (due to sprint too tight, too loose).
The most likely cause is probably a deformed isolator. You can take it out and examine it, maybe drill it out with a 3mm or 4mm drill. Ask UM for a new one (the newer ones are glass filled and withstand deformation a little better).
Again, another likely cause is gunk in the nozzle. Especially if you recently switched from ABS to PLA.
There's a great test to see how your machine is doing. It's important to do the test at 230C. Anything above 6mm^3/sec is pretty good. If it fails at 5mm or lower you should fix it:
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
gr5 1,837
http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/
