Posted
· Where am I going wrong? - Under-extrusion
Well, I'd say it's because you have the spring tension too loose or too tight.
I found it useful to make a small "coin" test print, say 25mm diameter and 2mm thick, .1mm layers, 55mm/s, 100% fill: it takes only a few minutes to print and each layer fill is a decent test of regular extrusion. I also used a loose length of filament say about a meter beyond the feeder, to eliminate spool binding as an influence. I backed off the spring screw to the min force then started off the print, tweaking it clockwise a quarter turn at a time until I got consistent fill.
Once I was happy with the coin I returned to the above extrusion test and got perfect results all the way to the top.
Oh, and it helps to take the time to get the bed levelling spot on. Otherwise that too could be an influence.
donmilne 2
