Oh thanks, will check. Didnt get a new temp probe.
The plastic insulation has a small cut close to the probe, exposing the metal insulation. Asked support and they told me this shouldnt be a problem. Gonna go to one of their meetings, AA but for ultimakers, next monday.
Will keep you updated
gr5 2,243
Your diagnosis of improper temperature sounds possible.
1) When you got the new hot end did you also get a new temperature probe?
2) Consider doing one more test to prove temperature error - set temp to 110C - let it sit at 110C for a full minute and then put a drop of water on the nozzle tip. Does it boil? A drop of water from my finger will boil away in about 4 seconds. You can see it bubbling. If I squirt water onto the block through the crack in the fan shroud it boils quite noisily and the temperature quickly drops to 99C but never lower than 99C.
3) Also if the printer has been off for an hour do the bed and nozzle report the same temperature? About 20C?
