How to build marlin firmware with makefile?
zhonghello
Posted · How to build marlin firmware with makefile?
Dears,
I want to build marlin firmware with makefile, and I have installed Arduino 1.5.2 and the install path is G:/software.
Then I changed makefile as below:
# This defined the board you are compiling for (see Configuration.h for the options)
HARDWARE_MOTHERBOARD ?= 72
# Arduino source install directory, and version number
ARDUINO_INSTALL_DIR ?= G:/software/arduino-1.5.2-windows/arduino-1.5.2
ARDUINO_VERSION ?= 152
# You can optionally set a path to the avr-gcc tools. Requires a trailing slash. (ex: /usr/local/avr-gcc/bin)
AVR_TOOLS_PATH ?= G:/software/arduino-1.5.2-windows/arduino-1.5.2/hardware/tools/avr/bin/
After changed the makefile, from a command prompt, I change into Marlin directory, and then type 'make', it shows below error:
G:\Marlin>make
make: *** No rule to make target `G:/Marlin/applet/wiring.o', neede
d by `G:/Marlin/applet/Marlin.elf'. Stop.
Very appreciated if any help~
PS: Actually, I am not sure about the arduino version :152
    I did a quick test here and the Ultimaker/Marlin compiles fine with the latest 'stable' Arduino 1.0 (1.0.5) and gives the error you get with 1.5 Beta (tested with 1.5.7).
    Unless you absolutely want/need to go ahead with 1.5, easiest is to install 1.0...
    1.5 probably requires some more tweak in the Makefiles -- note that 1.5.7 does not even have the avr-utils, which requires more work to setup a build environment...
    • 1 month later...
    Not entirely true, You get this issue also with 1.0.5 when using a wrong motherboard. The default right now is '11' in the Makefile. A patch I have in my local git repository looks like the following (tested on *ubuntu) for an UM2 which is motherboard version 72. Arduino is installed via apt-get and i think it now has a dependancy on the normal avrdude (avrdude.conf is a symlink to /etc/avrdude...)
    diff --git a/Marlin/Makefile b/Marlin/Makefile
    index d8c7d0a..481c454 100644
    --- a/Marlin/Makefile
    +++ b/Marlin/Makefile
    @@ -37,19 +37,19 @@
    # from the commandline with "make HARDWARE_MOTHERBOARD=71" for example
    -HARDWARE_MOTHERBOARD ?= 11
    +HARDWARE_MOTHERBOARD ?= 72
    -ARDUINO_INSTALL_DIR ?= ../../arduino-0022
    -ARDUINO_VERSION ?= 22
    +ARDUINO_INSTALL_DIR ?= /usr/share/arduino
    +ARDUINO_VERSION ?= 105
    AVR_TOOLS_PATH ?=
    #Programmer configuration
    UPLOAD_RATE ?= 115200
    -AVRDUDE_PROGRAMMER ?= arduino
    -UPLOAD_PORT ?= /dev/arduino
    +AVRDUDE_PROGRAMMER ?= wiring
    +UPLOAD_PORT ?= /dev/ultimaker2
    #Directory used to build files in, contains all the build files, from object files to the final hex file.
    BUILD_DIR ?= applet
    @@ -293,7 +293,7 @@ LDFLAGS = -lm
    # Programming support using avrdude. Settings and variables.
    AVRDUDE_PORT = $(UPLOAD_PORT)
    AVRDUDE_WRITE_FLASH = -U flash:w:$(BUILD_DIR)/$(TARGET).hex:i
    -AVRDUDE_FLAGS = -D -C $(ARDUINO_INSTALL_DIR)/hardware/tools/avr/etc/avrdude.conf \
    +AVRDUDE_FLAGS = -D -C $(ARDUINO_INSTALL_DIR)/hardware/tools/avrdude.conf \
    -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER) \
    -b $(UPLOAD_RATE)
    Well... Yeah...
    I meant to say that it works for building UM stock firmware...
    It also does not work out of the box if you try compile e.g. for a RepRep Full Display controller instead of the UltiController...
    Stock firmware is built from the '_do_make.bat' script where board and other options are set properly. This works perfectly and do not require any patch.
    Then obviously if you try anything else than that you are on your own...
    _do_make.bat however is very platform specific and requires patching when changing arduino versions etc. Also, _do_make.bat is basically patching the Makefile 'on the fly'.
    Since we're talking about UM's specifically here it's not unthinkable that RepRap based firmware won't build 'out of the box' ;)
