Hi guys,
Since i can print with my UMO+ i always had the same prob... Horizontal line always located in the same level... I have talk with other users having the same prob and they all never find a issue so i'm lost
i have upload some pictures with my prints and as you can see the line is located in the same lavel .. Dipend the layer config...
the blue filament is PLA : 0.06mm
The white is PLA and i printed with different config
this is the link to see my pictures and some vidéo
Thks in advance
gr5 1,872
I guess you could lower the acceleration. Do you have an ulticontroller on your machine?
Also it's common for people to not insert the Z screw completely inside the Z coupler that connects to the motor. Look again at the assembly instructions photo - you should see very little of the non-threaded portion of the Z screw above the coupler.
How do you know for sure that it is missing steps? Can you explain in more detail how you determined this?
