What are these plugs called, I need replacments. (hotend)
Posted · What are these plugs called, I need replacments. (hotend)
hi guys
these two plugs have worked themselve through the wires so I need to put replacments on.
I need the names of pins that attach to end ends of the wires and the connectors, any ideas?
Thanks in advance!
Will
IMG 2465
IMG 2464
    The connectors are commonly refered to as JST connectors, but it may be tricky to find the correct ones.
    The bits that you crimp around the wires are called connector contacts.
    http://uk.farnell.com/jst-japan-solderless-terminals?isRedirect=true
    • 3 months later...
        • 31 replies
        • 25 replies
