Skin feature
jcosmo
Hi all,
I don't think this is currently possible in Cura, but I thought I'd just in case I'm missing something.
I'd like to use the old 'skin' feature of the slicer which could slice the outer skin at 1/2 the layer height of the fill. It produces a nicer outer skin whilst spending less time on the unseen bit.
How do others achieve this these days?
Plugins for Cura?
Alternative slicers?
Thanks,
J.
    The 'old' cura was able to do this when skeinforge was still used as slicer. This slicer had a ton of functions, but it had a horrible codebase (complete mess, so almost impossible to improve). As a result, daid developed his own slicing software, aptly called the cura engine. This slicer doesn't support variable layer heights. There are no plugins that can fix this.
    Not sure if there is a plugin that can do this effect (as it can be done in a plugin). But I have a development version of Cura that can do "variable sparse infill thickness" where the sparse infill is every X layers.
    Posted · Skin feature
    I'm giving the 'Skipinfill' plugin a whirl, which appears to be capable of doing it.
    Only small objects so far, but will give a bigger one a go when I see how the current print turns out.
    Kisslicer offers the sparse infill feature, where infill is only laid down every N layers. I commonly use 2 as a value, so alternating infill layers go in alternate directions.
    It saves a ton of print time.
        • 24 replies
          • Heart
